NI TestStand
Hyperlink in MS Access Database
Hi.
I have a table within an MS Access database which has a column of type hyperlink. I am populating this column using the built in database tools in TestStand. I am passing in a path to a file which is of TestStand type String.
The database gets populated correctly with the required text, and looks like a proper hyperlink. Unfortunately, when the link is clicked in Access nothing happens - the link has no address associated with it (if that makes sense).
I have attached a sample sequence which shows the problem.
Has anyone come across this problem before, and if so, can it be overcome?
Cheers.
N.
(3,583 Views)
Neilelph
I have never used them before, but if I create a simple table with a hyperlink field and query the value as a string, the value that is returned is surrounded by # characters, i.e. "#d:\temp\temp.seq#". Try pushing the value into the database from TestStand using the extra surrounding # characters.
Scott Richardson
https://testeract.com
(3,578 Views)
That works a treat. Cheers.
(3,565 Views)
