NI TestStand
How to use Call executable to run a ping command?
i am using TestStand 2014 and want to use the Call Executable to open cmd.exe and run ping 127.0.0.1
For this i currently inserted C:\Windows\system32\cmd.exe at File Pathname and "ping 127.0.0.1" at Argument Expression.
But this only opens the command-window when executing the step.
How do i do it correct?
Edit.
Solved: Only the parameter /r was missing in Argument Expression before the Ping command.
(6,186 Views)
Accepted by topic author OnlyOne
Hi
         Ping is an independent executable tool. Its not an argument. The executable is under "C:\Windows\system32\PING.exe". Configure the step to call Ping.exe and give the arguments as "127.0.0.1".
You can use the sequence attached.
Sathish S
(6,101 Views)
