NI TestStand
How to turn on java console window
I am using TestStand to start up a Java VM and call some java methods. Runing the java application is fine. But when start it from TestStand, there are some weird thing happened on the Java side that cause TestStand to fail the java step. Could you suggest me how to turn on the Java console window, so that I can print some messages on the Console window for debugging?
Thanks in advance!
Message 1 of 1
(3,940 Views)
