NI TestStand
How to spare memory while using TestStand?
I've done a program with TestStand 1.01 and CVI 5.5. It works well but take
30 Mo RAM memory by UUT with a 1Mo sequence file.
I guess the TestStand configuration I use is not optimal.
What could be the typical reasons for memory consumption in TestStand?
What should I do to avoid memory problem?
Thanks for your help
(4,248 Views)
Edouard
You can set the load options for each step in the Properties.
I think by default all steps are Preload when execution begins. You could change this to Load Dynamically.
Select Properties (ALT + Enter), Select Run Options Tab, Select Load Options control.
Regards
Regards
Ray Farmer
(4,248 Views)
