NI TestStand
How to repeat one test sequence step?
You can discard the failed result in the SequenceFileStepFailure callback sequence then perform a repeat test. That way you will only get the one result ResultList.
Regards
Ray Farmer
Regards
Ray Farmer
Message 11 of 13
(1,688 Views)
I have a situation where I have 5 tests to be done on a perticular data channel, and I have 15 such channels in my unit under test with the same limits and parameters, so there are 75 steps in total. What i've done is i've created a sub sequence of the 5 tests and calling it for all 15 channels. I want to repeat a perticular step (not all the 5 tests but only one test of a perticular channel) if it fails for 3 times and declare pass only if it passes for all the three times. Is there any way in which I could accomplish this? Thank you
Lakshmi Narasimha
Message 12 of 13
(1,335 Views)
Hello Lnsimha93,
A solution would be the following. For each of the 5 steps in the subsequence:
  • Go to the Step Properties
  • Select the Looping tab
  • Choose Loop Type: Custom
  • Configure the following expressions:
    • Loop Initialization Expression: RunState.LoopIndex = 0
    • Loop Increment Expression: RunState.LoopIndex += 1
    • Loop While Expression: (RunState.LoopIndex==0) || (RunState.LoopIndex > RunState.LoopNumPassed ) && (RunState.LoopIndex< 4)
    • Loop Status Expression: RunState.LoopNumFailed< 2 ? "Passed" : "Failed"
I also attached a small demo.
  • Test 1 passes.
  • Test 2 fails initially. This triggers 3 repetitions of Test 2, which are all successful. (=> Passed)
  • Test 3 fails as well. The first repetition is unsuccessful, and the last two are successful. (=> Failed)
The final result is Failed.
This should accomplish your desired task. Please let us know if you have any other questions.
Message 13 of 13
(1,314 Views)
