NI TestStand
How to programmatically add a sequence file to a project
Using Teststand C++ API, I would like to add a sequence file to the current project in the current workspace.
My sequence file has been created using engine->NewSequenceFile(); and saved in the path "Path" (as std::string).
I try to create a new workspace file this way :
engine->CurrentWorkspaceFile->GetRootWorkspaceObject()->NewFile( _com_util::ConvertStringToBSTR(Path.c_str()) );
But this line throw a com exception "Unknown error 0xFFFFBC63" which should correspond to error -17309
What is the correct way to do this ?
Thank you.
(4,873 Views)
hello
Could you provide the code you're using, for example the order of functions you're calling?
So that we could look closer at your project.
Regards
(4,829 Views)
Thank you for your answer.
Here the code I'm using :
    string newSeqName = "myNewSequence";
    TS::SequenceFilePtr newSeqFile = _currentContext.engine->NewSequenceFile();
    TS::WorkspaceObjectPtr workspacePtr = _currentContext.engine->CurrentWorkspaceFile->GetRootWorkspaceObject();
    string chapterPath = getFolderFromFilePath(string(workspacePtr->GetPath())) + "\\";
    chapterPath += newSeqName + ".seq";
    try
        newSeqFile->Save(chapterPath.c_str());
    } catch (_com_error const & e) {
        gcLogModuleError("Error on save :  %s", e.ErrorMessage());
    TS::WorkspaceObjectPtr newSeqObj;
    try {
        newSeqObj = workspacePtr->NewFile( _com_util::ConvertStringToBSTR(chapterPath.c_str()) );
        gcLogModuleError("got error on newfile :  %s ", e.ErrorMessage());
workspacePtr->InsertObject(newSeqObj, workspacePtr->NumContainedObjects);
    _currentContext.engine->CurrentWorkspaceFile->AsPropertyObjectFile()->IncChangeCount();
    _currentContext.engine->ReleaseSequenceFile(newSeqFile);
    _currentContext.engine->SaveAllModifiedSeqFiles(0);
this code saves in the right place my file "NewSequence.seq"
Generate error TS_Err_IllegalOperationOnValue
(4,822 Views)
Looking at your code, the way to script TestStand is to - create a workspace, the create a project then create a sequence. It doesn't appear in your code that you create a project.
Please could you try this using the Workspace.Objectfile.Newfile(path du projet)? The project file extension is .tpj.
(4,803 Views)
I want to add a sequence to the current project of the current workspace but GetProjectFile() always give me an invalid pointer in :
_currentContext.engine->CurrentWorkspaceFile->RootWorkspaceObject->GetProjectFile()
If I create a new project, I don't see how to add a sequence to it once I got my TS::WorkspaceObjectPtr.
Is there documentation/example on this subject ?
Thank you.
(4,787 Views)
