NI TestStand
How to load programmatically from CVI the specific sequence file in TestStand 3.1
I am trying to implement TestStand from Windows/CVI 3.1. I need to insert a specific sequence file in TestStand, with all other sequences unloaded. I used TSUI_ApplicationMgrCloseAllSequenceFiles() and TSUI_ApplicationMgrOpenSequenceFile(), but after Username/Password prompt, the TestStand loaded all the old sequences. How to eliminate this?
(3,554 Views)
I created a function that calls those two methods. When I made a simple CVI button and in a callback for it, I call my function, it does successfully close all open sequencefiles and then load the one I specified; however, it does not work when I call the function just before the call to RunUserInterface! I am very surprised by this and will be bringing it up with our R&D department. There is a simple work-around. Instead of closing all open sequencefiles at the beginning of the OI, close them at the end instead. I have modified the full-featured OI for you and tagged in the code where I made changes. This should do exactly what you want (you may want to change the code around to make it a little cleaner...I left more in code in than I needed for instructive purposes). Please let me know if you have any questions about this. Take care!
Aaron B.
(3,540 Views)
Before calling ApplicationMgr.Start(), set the ApplicationMgr.ReloadSequenceFilesOnStart property to false.
(3,534 Views)
