NI TestStand
How to join to bytearrays with MSB / LSB to real number?
i have two numeric arrays. One with MSB bytes and the other with LSB bytes.
How can i join this two bytes into a third array with the full number?
Thx
(5,006 Views)
I would make a for loop.  Inside the loop, you would have something like Array3[i] = (MSB[i]<<8) + LSB[i]
I don't think there's a join command.  You need to left shift the MSB and add it to the LSB.
Pulido Technologies LLC
(4,998 Views)
Hi!
it is much easier than that. Join really works for that (see demo)
EDIT: Sorry I missread. I thought it was a LabVIEW question!
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(4,960 Views)
USe a For loop loopin the number of elements in the  MSB array and put this statement inside the loop will join the arrays.
Locals.ResultArray+={Locals.MSB[Locals.Index],Locals.LSB[Locals.Index]}
So something like this
For (Locals.Index = 0,Locals.Index < GetNumElements( Locals.MSB),Locals.Index += 1)
End
BR
Christian
(4,904 Views)
