08-25-2008 09:11 PM - edited 08-25-2008 09:13 PM
In preUUTloop the operator is polled to choose a few parameters (messages with 2-3 buttons to choose from)
How do I record his choces in the report?
Desirably, this data should be reported in the very beginning on the report only, not in every UUT loop.
TS3.5
Thank you!
08-27-2008 01:21 AM
Take a look at this example.
I have attached it to every uut just to demonstrate how it works
I your case i would also override the ModifyReportHeader Callback and add it Report header
wich is a little bit of work.
Greetings
juergen
08-27-2008 01:37 AM - edited 08-27-2008 01:40 AM
Hello Fomine,
We have a Developer Zone that I believe fits your needs here. I found this by searching "add extra results to report" at ni.com
As a side note, this is extremely easy in TestStand 4.1 (as seen by the help here). Could I have a sales representative contact you about upgrading? If so just let me know (don't post your information) and I will get your email and get in touch with you.
edit: Beaten by juergen with example code too! Thanks juergen you are truly appreciated!
09-04-2008 06:36 PM
Hi j_dodek,
Thank you for your help!
I implemented it similarly, for now, but what I really needed is the Modifying HTML Report Headers to Include Custom Information. Thanks for pointing me in the right direction. I will get back if I cannot make it work.
Hi Dr. Doiron
Thank you, interesting method is there, even though not what I needed.
