NI TestStand
How to get the Process Model sequence file name
I am using RunState.Root.ProcessModelClient.HasModel to check if the client sequence is executed using process model. I now need to find if the sequence was executed using Single Pass or TestUUTs model. How can I get the name of the process model sequence file?, thanks!!
CLD
(3,322 Views)
RunState.Root.RunState.Sequence.Name
RunState.Execution.ModelSequenceFilePath
(3,319 Views)
