NI TestStand
How to get UUTPassed and UUTFailed count from C# ActiveX control
My operator interface uses TestStand ActiveX control in C#. I will use the OP to test a bench of DUTs, which runs the same sequence file. I would like to know the total UUT-Tested, UUTPassed and UUTFailed count after each DUT tested. Is there any embedded parameter does the job for me and how could I get it? If there is not, I have to create internal variables in C# to do the job.
(3,072 Views)
Accepted by topic author 0049
No, there is no build in function for this. So either you will have to implement something like this in on of the following:
a) The user interface
b) The SequenceFile (as long as it is not unloaded in between)
c) The process model
d) Use an external tool for analysis
If you are already working with databases for reporting, i would suggest using d). If not, you can choose. But modifying the process model is not recommended (if other, simple solutions are available), i wouldn't recommend c).
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,032 Views)
Good to know!
Thanks Norbert
(3,029 Views)
