NI TestStand
How to do 'Unload all models' programatically?
I wish to perform 'Unload all models' upon the completion of my sequence.
Is there a way to do it programatically?
Rafi
(5,530 Views)
Yes, you can call the method Engine.UnloadAllModules.  One way this call could be added would be to add the postUUT callback to your sequence file and then add an ActiveX/COM action using this method to the postUUT sequence.
The TestStand API Reference Guide located in the TestStand help has information on this method and many others.  Searching within the TestStand help for "unload modules" will also return more information about this method.
Feel free to ask if you need help creating a callback or doing a method call.
Message Edited by Dillon G on 07-30-2007 04:08 PM
(5,518 Views)
So what Object Reference should be used when using this method (Engine.UnloadAllModules)?
(5,074 Views)
You can use a Statement step in TestStand and simply use RunState.Engine.UnloadAllModules().
(5,071 Views)
Daniel,
The problem I am having is I am getting an error when I close TestStand (see attachment), but when I use the File pull-down menu to Unload All Modules, the problem goes away???
(5,069 Views)
This would suggest that you are not deallocating memory / closing references in one or more of your code modules (vi, dll may be?)
I would skip some sections of the code to narrow it down.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(5,051 Views)
That can sometimes happen if you have code that is attempting to call into a dll after it has already been unloaded. That should normally not ever happen. But perhaps you have code that calls into a dll when something gets cleaned up for shutdown that doesn't own a strong reference to a dll or appdomain thus not keeping it loaded.
-Doug
(4,814 Views)
