NI TestStand
How to determine if in Interactive mode?
In the process model, I need to determine if the client sequence file was run in Interactive mode. I found a method called Execution.InInteractiveMode(), but I don't know how to get an ActiveX reference to the Execution object.
(3,075 Views)
Every SequenceContext has an Execution property. You can use the expression "Execution" for the reference to the Execution object.
Scott Richardson NI
Scott Richardson
https://testeract.com
(3,075 Views)
Thanks, that works. This way I can differentiate between complete and partial sequences when logging results to the database. I used an ActiveX step with a reference to "RunState.Execution".
(3,075 Views)
