06-02-2017 03:37 PM
I run a command line command, say ping, which will contain either "Request timed out" if the target doesn't respond or "Reply from" if it does. The step settings specify that "Step.StdOutput.Text" should receive the output of this command. I want to search this output for the ping response strings, and then set the step as pass or fail accordingly.
How can that be done?
Tia
06-02-2017 09:18 PM
