NI TestStand
How to change step.arguments on Preconditions?
I'm trying to change the Step.Arguments value during the Run State of the Sequence on the Preconditions, but I'm not able to execute it. The main idea is to:
1) Set the Step Argument Expression on the Call Settings tab as: "/K echo HELLO"
2) During the Run State, change the Step Argument Expression to:  "/K echo GOODBYE. " with the following expression on the Preconditions tab:
Step.Arguments =  "/K echo GOODBYE. ",
But the following errors appear:
ERROR 1: Error in Argument Expression Unexpected token: /
ERROR 2: The following error occurred while logging additional result 'Arguments': Error in call to expression function 'Evaluate'.
Unexpected token: /
What would be the correct way to change the Step Arguments text?
(2,858 Views)
Accepted by topic author HelenMunoz
Because Step.Arguments is an expression you have to enter it as such:
Step.Arguments = "\"/K echo GOODBYE.\""
Try that.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,851 Views)
Thanks a lot!!!! It Does Work!!!
(2,822 Views)
