NI TestStand
How to add results to report from sequence call disabled in report options ?
I need to add text to report from a sequence called by a sequence call. The record results option for the sequence call is disabled because the sequence call is normally done thousands of times. Therefore, I don't want to fill in useless text in the report. But, if a certain condition in called sequence fulfills, I would put a text into the report. (Yes, this is related to a sporadic communication problem with the instrument which I want to record into the report.) Which options I have ?
I have attached an example which doesn't add the text from the sequence to the report.
Petri
(3,385 Views)
Hi Petri,
One way would be to have a None adapter step set to record, and you call when every your problem occurs
eg
IF (expression)
     ok
ELSE
     NONE Adapter step set to record problem
END
You dont want to just include a step with a precondition as it will get recorded as Skipped.
Regards
Ray Farmer
Message Edited by Ray Farmer on 06-08-2006 09:21 AM
Regards
Ray Farmer
(3,378 Views)
Hello Ray,
I encounter same behaviour with NONE adapter action step with post-expression as with a statement step as in my first example. With other words, if record results in sequence call in mainsequence is disabled, I cannot get any records into the report.
Attached a modified sequence using NONE adapter action.
Petri
(3,375 Views)
Petri,
You have to actually have the MainSequence and sub sequence Report Option set to allow reporting with all other steps switch off except for the None Adapter step for this to work.
Is you MainSequence/SubSequence only called once?
Regards
Ray Farmer
Regards
Ray Farmer
(3,369 Views)
My subsequence is called thousands of times during a complete test. Therefore, I don't want any "begin sequence ... end sequence" text in report.
Petri
(3,367 Views)
