NI TestStand
How to add a container object in a station global in a vb.net application
to summarize I want to add a container object in a station global in a vb.net application.
I managed to add a string and a number with PropertyObject.SetValNumber and PropertyObject.SetValString but I failed to add a container object because I dont find a suitable Property?
Message 1 of 16
(4,713 Views)
Hi Radlou
You have use PropertyObject.SetPropertyObject(...)
You like to add? Tell me how you have created your container?
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 16
(4,711 Views)
In fact I have to complete a station global and sometimes I need to add a container object
Message 3 of 16
(4,708 Views)
How did you create the container in VB.net ?
Regards
Juergen
--Signature--
Message 4 of 16
(4,706 Views)
The station global was created manually,I have juste to complete it
Message 5 of 16
(4,704 Views)
Hi Radlou
If possible, post a screenshot of your container and what item(s) you like to change
Regards
Juergen
--Signature--
Message 6 of 16
(4,700 Views)
In can change a variable but i can't add a container
Message 7 of 16
(4,697 Views)
Hi Radlou,
Yes you can !
1. Step is to create the Container
Locals.objContainer =ThisContext.Engine.NewPropertyObject(PropValType_Container,False,"",0)
2. Add Subentrys to the Container
Locals.objContainer.AsPropertyObject.SetValString("strHello",PropOption_InsertIfMissing,"HelloWorld"),
Locals.objContainer.AsPropertyObject.SetValString("strName",PropOption_InsertIfMissing,"Juergen")
3. Add it to Station Globals
ThisContext.AsPropertyObject().SetPropertyObject("StationGlobals.MyStuff",PropOption_InsertIfMissing, Locals.objContainer)
Best would be a screeshoot
Hope this Helps
Juergen
--Signature--
Message 8 of 16
(4,695 Views)
Thank you, for your help
I try this but to add a container below Service1 which is also a container but it not work !
Dim O_glb As NationalInstruments.TestStand.Interop.API.PropertyObject
O_glb.NewPropertyObject(PropertyValueTypes.PropValType_Container, False, "TS.Service1.Val", 0)
Message 9 of 16
(4,692 Views)
Dim O_glb As NationalInstruments.TestStand.Interop.API.Engine
Message 10 of 16
(4,690 Views)
