NI TestStand
How to Log Sequence execution Results in my own SQL database?
Hello
I have a requirement where i need to get sequence execution results to be logged in a sql database which i have created.
Regards
Nitin Goel
(3,278 Views)
Check out Chapter 6 of the NI TestStand Reference Manual.
Regards
Ray Farmer
Regards
Ray Farmer
(3,276 Views)
Thanks for the early reply Ray.
after going through the content in Chapter6, i think it should be possible to direct the results of a test sequence to a user defined database BUT still i am not very clear with how exactly i can link to a comletely new ".mdf" file lying at some other location instead of TS directory. Even when i tried to follow the path to create a ".udl" file i was not able to do that instead getting an error msg as attached:
Path name used was as follows
Data Source=.\SQLEXPRESS;AttachDbFilename="~\Test.mdf";Integrated Security=True;User Instance=True
Regards
Nitin Goel
(3,274 Views)
Nithin -
The error message suggests that you selected the Microsoft OLE-DB Provider for ODBC Drivers. I would think that you should have used the SQL Native Client provider instead that is typically installed with SQL Express.
Scott Richardson
https://testeract.com
(3,216 Views)
