NI TestStand
How to Go to Start of test / Previous Sequence based on Particular step failure
Hello all
based on a particular test failure, i want TestStand (2022 Version) to then go back to the START of test, or any sequence of my choosing
The 'GoTo' function seems to limit you to the sub sequence you are currently in
Ex.
Sequence 1
Sequence 2
Sequence 3
     - Step fails within sequence 3
TestStand action to then go back to Sequence 1 and reiterate through test*
(905 Views)
In the step properties go to On Fail setting as shown below :
Select the sequence to where it should jump on failure.
Ravi
(891 Views)
