NI TestStand
How to Find Calling Sequence File
Sequence File B can be called by Sequence File A, or run by itself.
How do I find out, in sequence file B, that it's called by A, or run by itself at runtime?
In A, the Sequence Call "Execution Options" is "Use New Execution".
B is called multiple times in A and both in Single Pass and Test UUTs.
George Zou
Message 1 of 9
(2,106 Views)
If you want to find out during runtime from where a module is called, use a breakpoint and investigate the Call Stack
I highly reccomend %TestStandpublic%\Examples\Fundamentals\Structure of TestStand Executions to learn about it.
Message 2 of 9
(2,075 Views)
Thanks for reply.  This is a very good example.
But my case is a little different from the example: I have to deal with multiple sequence files.
At runtime, the call stack only show 2 items:
the model seq., and seq. B.
The caller, Seq. A, doesn't show up.
George Zou
Message 3 of 9
(2,056 Views)
Sorry, I don't undestand your description ... could you please proved further information  or a screenshoot please?
Message 4 of 9
(2,021 Views)
When sequence file B is called by sequence file A, on the call stack, only 2 items:
the SequentialModal.seq, and sequence file B.
George Zou
Message 5 of 9
(2,012 Views)
Ok, now I get it
If A.seq calls B.seq with an "ordinary" sequence call, you will see a call stack like this
If A.seq calls B.seq starting B.seq using a process model, you will see something like this (I guess that's what you are referring to)
For the records: If A.seq calls B.seq starting B.seq without a process model, you will see something like this
So why is this:
An new execution is an independent entity, which does not know about its' caller.
Message 6 of 9
(1,993 Views)
That's what I thought.
Alternatively, is there a way to find out if A.seq is running?
George Zou
Message 7 of 9
(1,965 Views)
Accepted by topic author zou
Well you can tell if the execution reference is still active, this yould be an inidcator.
Guess you could also set up a communication queue for both executions to send heartbeat messages or sth alike
Message 8 of 9
(1,963 Views)
Not sure how to get execution reference of A.seq in B.seq.
But queue works.
George Zou
Message 9 of 9
(1,955 Views)
