NI TestStand
How to Enable Edit Step Name manually in the Sequence editor
I accidentally disable the step name rename function in the sequence editor.  Now F2 doesn't work.  Rename....F2  is grayed out on the right-click menu.
How do I enable step name editing?
TestStand version 2017 on Windows 10 Pro.
George Zou
(916 Views)
Accepted by topic author zou
Figured out:
The Step column is not the 1st column.
George Zou
(894 Views)
