NI TestStand
How to Access to PropertyObject throught two referenced objects
I would like to access Parameters.Pdc_ValAttendue.valAttendue object reference and value but I fail.
Please see the debug windows where you can view that I have tried some API methods without any success
(5,755 Views)
What version of TestStand are you using? In recent versions of TestStand you can use the dereference operator as follows:
**(Parameters.Pdc_ValAttendue)
It's a bit unusual to have two-levels of object references though. You should really only need one level of object reference variables in most cases in which case:
Would have been sufficient.
Hope this helps,
-Doug
(5,711 Views)
I am using TestStand 4.2.
Is there another solution please ?
(5,707 Views)
Maybe its that I use the wrong method to assign a temp variable.
I should assign it using antoher way to keep safe the variable object valAttendue type and value.
(5,683 Views)
To get the value you could do something like this:
Locals.obj.GetValInterface("", 0).AsPropertyObject.GetValBoolean("", 0)
But you will need to do something like this to set the value:
Locals.obj.GetValInterface("", 0).AsPropertyObject.SetValBoolean("", 0, newValue)
-Doug
(5,665 Views)
How exactly are you setting this variable?
-Doug
(5,664 Views)
It's ok now. I have assigned my vars through another way.
(5,626 Views)
