NI TestStand
How set number of loops for step?
Hello everyone.
One of the options of TestStand is setting number of loops for specific step:
Sequence--> Step Properties--> Loop options--> Fixed number of loops-->  Number of loops.
Can i perform this settings programmly in my application?( I use LabWindow CVI 8.0)
If yes, how can i do this and which  TestStand functions is usefull?
Sincerely,
Olga
(3,658 Views)
Hello Olga,
do not select fixed number of loops in the loop options tab of the step properties, but select custom. You will find a set of expressions which can be defined and employed to dynamically define the number of loops to run.
Tab should look like the following:
1. Loop Initialization Expression
RunState.LoopIndex = 0 (If you want to start from 0)
2. Loop Increment Expression
RunState.LoopIndex += 1 (If you do always increment by 1)
3. Loop While Expression
RunState.LoopIndex < 10
Now define a local variable of type numeric with the name 'LoopCount' and use this through the expression browser to replace the value of 10. Should finally look like:
RunState.LoopIndex < Locals.LoopCount
Now you are almost finished and simply need to write a step in CVI which uses the lookupstring 'Locals.LoopCount' to transfer a loop count value from CVI to TS by calling the function 'TS Property Set Val Number'.
Hope this helps,
C.L. - National Instruments Application Engineering
PS: Out of office for one week
(3,656 Views)
