NI TestStand
How frame drop test is executed using PQA in TestStand ?
What format is the video output from your mobile device? If the mobile output is not true HDMI, that might explain the problem; the PXIe-1491 requires that the video input strictly adhere to the HDMI standard. (Most problems with out-of-spec video result in errors in PQA, however.)
I also tried to play the video that was playing in the video and took the Monitor Out from the NI PxI e 1491 to a TV. I was able to play as well.
Bharath
--Bharath
Message 11 of 12
(940 Views)
Hi ,
I tried rebooting the system and now I am able to collect the data and I also see the Video in Video/Audio tab.
Thanks for your time and help K_Joy
Bharath
--Bharath
Message 12 of 12
(934 Views)
