NI TestStand
How do I split a result report into two reports after executing a script?
How do I split a result report into two reports after executing a script, for example, the red line in the figure is used as the dividing line, and I want to split the same report into two main headings to present the report, how should I do it?
(1,066 Views)
IF there is some kind of regular pattern/ config ... to which your reports are to be split, you might implement sth. like this using a custom report plugin based on what you are using now.
Yet it might be more efficient to have a post-processing script which is run after actual report generation. (Though you could also run this script as a part of the execution. Sth like: duplicate the original XML and delete the unwanted tags in the according copy...
(1,038 Views)
Not sure if your intent is clear enough, do you want to split the report into 2 files or 1 file but 2 sections?
If you want tests 4 - 10 to be in a separate table in the same report just create a new sequence and move tests 4 -10 into the new sequence.  Then, in your original sequence file add a Sequence Call to the new sequence.
After you run these updates, you will find the tests 4 -10 will be a separate table with a header named after your new sequence.
(1,021 Views)
