NI TestStand
How do I search all LabVIEW VIs in a TestStand sequence?
I have a TestStand sequence that calls a hierarch of other TestStand sequences, and many of these call LabVIEW VIs. I want to perform a LabVIEW search on all VIs in this hierarchy.
If I could programmatically list all these VIs, I could take it from there by opening all the VIs then performing the search. Is there a way to do this?
(4,881 Views)
This may help.
Lemme know if you have questions.
Cheers,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,872 Views)
That works well on the top level sequence, but it does not recurse into subsequences. I will hunt around to see if this is possible and post back if I find anything.
(4,782 Views)
You should be able to turn the loop into a re-enterant share clones sub vi and use a recurseive call to itself in case "Sequence"
Thanks for the gem Jigg
That will help me out of a nasty jam
"Should be" isn't "Is" -Jay
(4,755 Views)
