NI TestStand
How do I dynamically reload different generations of database schemas in TestStand?
Hi
I have 2 sequence files A.seq and B.seq on one test station (one computer).
I want to save the result from A.seq using the “2.x to 4.0” schema “TS 2.x-4.0 Generic Recordset (NI)”
I want to save the result from B.seq using the “2012 and later” schema “Generic Recordset (NI)”
The problem seems to be that in order to change the schema I have to do the following.
1 Configure\Result Processing
2 Database
3 Schemas\Reload NI Schemas
4 select “2012 and later”
5 OK,
6 select “Generic Recordset (NI)”
7 OK, OK
How can I do this programmatically / on the fly from the sequence file?
It’s not enough to simply put:
Parameters.DatabaseOptions.DatabaseSchema.Name = "Generic Recordset (NI)" in "DatabaseOptions"
because this will apparently not load the necessary modules to TestStand.
Yours sincerely,
Erik
(3,408 Views)
NI come with the suggestion to copy the schema from “2.x to 4.0” to, in this case, “2012 and later” schemas.
I copied the schema “TS 2.x-4.0 Generic Recordset (NI)” under "2.x to 4.0" to the schemas under “2012 and later”
When copying the schema the name of the schema changed from
“TS 2.x-4.0 Generic Recordset (NI)” to
“TS 2.x-4.0 Generic Recordset”
In TestStand I then selected “2012 and later” schemas and put
Parameters.DatabaseOptions.DatabaseSchema.Name = "TS 2.x-4.0 Generic Recordset" in A.seq and
Parameters.DatabaseOptions.DatabaseSchema.Name = "Generic Recordset (NI)" in B.seq
This made it possible to access to the two different databases without reloading the schemas .
(3,290 Views)
