NI TestStand
How do I convert a HTML file to XML?
I generated a lot of files using TestStand report generation in HTML. I would now like to convert these HTML files to XML using the stylesheet found in the ..\TestStand\Examples\XMLReports\TestStandModels\ directory, but how do I do that?
(3,252 Views)
In that folder you quoted is a readme file. Follow the instructions and you should get a working example. Remember to backup the TestStand folder before you start.
Regards
Ray Farmer
Regards
Ray Farmer
(3,252 Views)
I think you misinterpreted the question, it does get a little confusing. I know how to switch between HTML and XML report generation of new tests. The questions is with all the HTML files that have BEEN created already, how do I convert them over to XML format?
(3,252 Views)
