NI TestStand
How can i call a step,which is in a subsequence, from a different subsequence
        Hi , Could someone help me, Please?
        How can i call a step,which is in a subsequence, from a different subsequence.
        For example:
        Two sub sequence, one is called A, the other one is called B. In B sequence , there is a Step Called BStep.
        In A sequence, there is a Step Called AStep.
         Now, i Hope  AStep can call BStep, How can i do?
        Thank you in advance!
(4,279 Views)
Accepted by topic author AllanXu
Allan,
What you are asking to do is not a good software practice.  It's like saying you want to call just one line of code out of a DLL.
The best way to do what you want is to put the step into a 3rd subsequence.  Then parameterize the subsequence with the parameters to the step.  Then call that 3rd subsequence from both A sequence and B sequence.
This way whenever you update the step they both get the changes.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,270 Views)
Thank you!
(4,258 Views)
