08-02-2018 09:05 PM
For example ,I have write 2 sequence files ,I call them a.seq and b.seq.two sequences are run normally in batch model,can i realize my idea?i do not want ues sequence call because it can only call the "main " or others.I want to the whole sequence.
08-03-2018 04:45 AM
Whats your actual requirement? What do you want to achieve with thw0 seq Files a.Seq & b.Seq?
Sequence can be called as a sub seq by a calling seq.
