NI TestStand
How can I open an external application using NI TestStand?
Hello All,
I have 2019-32 bit TestStand and 2019-32 bit LabVIEW. I want to open VI package manager application using NI TestStand sequence and want to check the current version of a particular(ex: Datalogging Library) labVIEW library installed. Manually it is easy to check the version of any library, but I would like to automate it in TestStand by creating a sequence. Your inputs are very much welcomed.
Thanks in advance!
Preeti
(1,536 Views)
Does VIPM have an API that you can check those things with?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,510 Views)
Looks like it does: https://support.vipm.io/hc/en-us/articles/214136183-VIPM-API
My suggestion is to call those VIs directly from TestStand.
jigg
CTA, CLA
testeract.com
(1,507 Views)
Hello Jigg,
Thank you for the VIPM API. It was helpful.
(1,494 Views)
