04-14-2009 04:54 AM
I have used additional result to display the array in graph format not in table format.But how can I customise this graph.
Is their any provision for customisation of graph adding axis and multiple line in single graph.
we can choose graph ond table from report option.But can we choose both as per our requirement step wise.Example for step 1 we can use tabel and for step 2 we can chose graph.
thanks ,
Kulwant Singh
04-15-2009 06:47 AM - last edited on 10-20-2024 10:05 PM by Content Cleaner
Waveform, XY, intensity, digital waveform support multiple x- and y-scales, and all charts support multiple y-scales. Mixed signal graphs support only one x-scale. Use multiple scales on a graph or chart to display multiple plots that do not share a common x- or y-scale.
Complete the following steps to add a scale to a waveform graph or chart.
04-15-2009 07:35 AM
Hello MR. Anonymous,
Thanks for your kind help.
Actually I am talking about NI teststand not LabVIEW.
I didn't mentioned the product as it is teststand forum.
Thanks again.
With warm regards,
Kulwant Singh
04-17-2009 10:29 AM
I think you need to see what can be done in reportgen_html.seq because this is the file which generates the report.
the report options callback is actually called before the sequence is run so thr is no point adding the steps there.
Reply if you get something.
regards,
Vaibhav
07-20-2011 10:23 AM
I have a similar problem: I have a VI which has as output an analog waveform. I use this VI in my teststand sequence and this output has been configured as additional result. The displaing of the waveform in testreport is working fine, but the problem is that the Y-scale will be scaled automaticaly and scale labels are not more available. Unfortunately it looks like the settings in VI will be ignored by teststand while generating of the testreport. I'm using xml as report format and expand.xsl stylesheet. Some users talked about modifications in reportgen_***.seq, but is it only possibility to resolve this problem? Did alredy anyone experience with this?
Thanks and regards
07-21-2011 01:43 PM - last edited on 10-20-2024 10:05 PM by Content Cleaner
TestStand 2010 supports some customization of graphs in reports via attribute settings. See the following for more details:
https://www.ni.com/docs/en-US/bundle/teststand/page/displaying-measurement-data-as-graphs.html
-Doug
