06-06-2011 04:29 PM
I have an sequence where data is read into the sequence file from an access database table. Now I want to write this data to another database table. How can I add this data to the database scheme in Teststand(based on 'Generic recordset NI').
07-27-2011 05:18 AM
Hi Jimi,
After looking to your problem I found out that you can add your data to the datasheet scheme based on "Generic recordset NI" in Teststand by creating a new data table in Teststand as mentioned in the link below.
Besides it is useful to make a copy of Generic recordset NI.
http://zone.ni.com/devzone/cda/tut/p/id/6484
I hope this helps. Good luck.
Hossein128
