NI TestStand
Hide preloading module window and show customized window instead of preload window
I need to show my own customized window during modules loading instead of preloading modules  window comes with teststand when sequence file loading, how to do this. Any help?
Anand
(3,862 Views)
Insert the PreUUT Model Callback into your sequence. Then skip the 'Call DoPreUUT'  step in the PreUUT Main. Add your custom step after that.
Curt
(3,830 Views)
Hi Curt,
I tried that . It did not work.
Here is the description of the requirement.
I am using teststand simple user interface and customized for my requirement. The problem is when i load the client sequence file or when i start the sequence . I will get a popup which shows what are the sequence are loading and its complete path of client sequence file and process model file. I don't want to show this to user. Instead i should show a dialog message with an image and it should just show "Loading".
which is the step responsible for bringing the loading screen. how can i customize it.
Anand
Anand
(3,816 Views)
Do you sovle it?I‘m meeting the same question.
(3,522 Views)
I'm also having the same issue. Does anyone know a solution?
Steven Dusing
CLA, CTA
(666 Views)
