12-11-2008 12:14 AM
Solved! Go to Solution.
12-22-2008 09:23 AM
kpraveen,
I looked at the files attached to that KnowledgeBase, and saw that they were modified versions of the files that shipped with TestStand 3.0. Because we have made some changes to those files since that version, there is no guarantee that they will work with the most current version of TestStand.
If you need this behavior in a newer version, you can modify the reportgen_ sequence files yourself. You will need to create the modifyheader and modifyfooter sequences in thost sequence files and then call those sequences from the Process OTF result sequence. We are working on a more detailed set of instructions, and I will post here when they are available.
12-24-2008 04:23 AM
01-12-2009 04:36 PM - edited 01-12-2009 04:37 PM
kpraveen,
The KnowledgeBase you referenced above: ModifyReportHeader and ModifyReportFooter Callbacks Not Called When the On-The-Fly Reporting Option ... has been updated.
It now includes a set of files that can be used with TestStand 4.0, and has instructions for how to modify your sequence files for any version to have this capability. Hope this helps!
08-20-2009 08:15 AM - edited 08-20-2009 08:23 AM
The link http://ae.natinst.com/operations/ae/public.nsf/$CXIV/ATTACH-AEEE-7MFPC5/$FILE/Modified%20OnTheFly%20... seems to be broken.
Result:
Oops! This link appears to be broken.
Also the images are not displayed.
I tried opening the page using Internet explorer 7 and Fire fox 3.5.2
08-20-2009 11:13 AM - edited 08-20-2009 11:14 AM
Hi Vidula,
The images and attachments have been fixed. You should now be able to download the attachments.
05-20-2011 09:24 PM
Is there update steps for TestStand 4.2? I'm running into the exact same problem. Thanks in advance.
05-26-2011 03:58 PM
There are steps in the article below that explain how to modify the shipped .seq files on your machine to modify the behavior. Have you tried following them?
ModifyReportHeader and ModifyReportFooter Callbacks Not Called When the On-The-Fly Reporting Option is Enabled
http://digital.ni.com/public.nsf/allkb/05F43468942BE32E86256D980074E200
