NI TestStand
Handling events/delegates within TestStand
Has anyone got any experience of handling delegates or events within  from a C# assembly? My application issues an event to inform that a time consuming operation has completed its running. I would like TestStand to handle the event directly and trigger some operation when the event is seen rather than having to write a C# wrapper application to handle the event when it occurs.
I am interested in knowing the following, if indeed they are possible:
1) how to setup my TestStand sequence to register for reception of an event
2) how to trigger a step asynchronously when the event is seen
Thanks in advance.
Ben
(3,775 Views)
Hi Ben,
Hope you are doing well today! What kind of event is it? ActiveX or some other?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,759 Views)
Hi Adnan,
Im very well, thanks for asking. Its an event which is broadcast from a C# code module, so it is similar to a function pointer in a C++ app. I am not sure how similar this is to an ActiveX event however as c# uses .NET technology rather than COM, and I am not as familiar with COM.
Many thanks,
Ben
(3,737 Views)
There is no mechanism for listening to .NET events in TestStand.  You will need to create a code module to do this, and most likely launch it in a new thread.  Once an event happens, you could have another thread that is listening for incoming items on a Queue execute a specific squence once an event happened.  In your event handling code, you could post items to the queue so that TestStand could execute a sequence whenever the event occured.
There are more possible solutions, so if your needs are different, an alternative might be better.
Allen P.
NI
(3,731 Views)
Hi Allen,
Thanks for your useful feedback. I thought that this might be the case. I like the sound of the queue idea, so will investigate that further.
Ben Lawler
(3,729 Views)
