NI TestStand
HTML REPORT
Hello
I want to make a HTML report per day, including all the executions run of this given day. I found out that in TS 3.1 there is an option (Configure> Report Options> Contents> Append if file already exists) but it does not sem to work. What actually happens is that a series of reports is generated with the same base name plus a number (i.e. Report.html, Report_000002.html and so on).
Is there a way to append these HTML reports?
(3,190 Views)
This only works if you haven't got any other the other options on, such as date & time or force file name to be unique. Have a look at the options in the Report File Pathname Tab of the report options dialog.
Regards
Ray Farmer
Regards
Ray Farmer
(3,183 Views)
Now I did it.
I have missed that "Force 2 b unique" option, and now it works.
Thanx 😃
(3,171 Views)
