NI TestStand
Getting the run mode of a step in run time
Is it possible to get the run mode of a step at run mode? I would like to skip a section of my sequence depending of the run mode of a group of steps (ie if all are marked as 'skip' I want to jump directly at the end of the sequence).
Yannick Willener
(3,769 Views)
Hi Yannick,
Here is a little example which gets the number of steps in Main. Checks the run mode of each step and sets a SkipCount.
If the skipCount equals the number of steps in Main then jumps to cleanup.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,769 Views)
Thank you!
(3,769 Views)
