04-29-2009 05:36 PM
I am calling a stored procedure in TestStand 4 however when I try to retrieve an output parameter using Get, an error of "The column '@X' was not returned from the SQL statement.". I have setup the parameters including '@X' using Execute in the previous step. I would appreciate it if someone could take a quick look to see if there is a small error being made.
05-05-2009 04:47 PM
