02-19-2010 08:16 PM
02-19-2010 08:37 PM
02-22-2010 09:12 AM
I experienced a somewhat similar behavior. When running a couple of tests on DUTs consecutively, which generate XML test reports of about 9MB each, I got an memory error when TS wanted to create the test report.
Only closing and reopening TS solved this problem, I couldn't figure out another workaround.
02-22-2010 01:06 PM
When starting TestStand fresh, it is more likely that a large enough contiguous block of memory will be available for such large reports, than if the TestStand process has been open and in use for a while.
We are looking into making this better in future versions of TestStand, however, for the time being these limitations do exist when using the XML (or ATML) report formats. To workaround this behavior, you could possibly split the report up into smaller file sizes.
Hope this helps.
02-22-2010 04:55 PM
Okay, we can work around the problem.
Thanks, Mark
11-10-2010 09:22 AM
11-11-2010 10:58 AM
Steve -
The ASCII and HTML report formats handle this much better and do provide the option to "dump the report incrementally" however, the XML and ATML report formats currently do not support this functionality.
11-19-2010 08:30 AM
