NI TestStand
Function Contains in TestStand
I am trying to find a cluster in an array of clusters in teststand using the Contains(array, object, <caseSensitive>) but it actually doesn't work, would anyone have an idea how to make it identify the cluster or am I missing something?
Thank you
(3,457 Views)
The names have to be the same.  So basically you need something like a named array.
Attached is an image of what I did to make it work.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,443 Views)
I am inserting data from an output of a function , in the execution of the sequence and when I am using the watch view I can see that the cluster I am searching appears in the array of the clusters (containers), So it the contain function must return true.
Even if I put the same name, at execution names will disappear (I don't know why) and the test is always failed.
I will be happy to hear from you about this issue
Thank you
(3,430 Views)
Without more specific details in your situation I couldn't tell you how to solve your issue.  However, if the names don't match the Contains function will return false.
I don't understand what you mean by "names will disappear"?  Can you elaborate more on that?
jigg
CTA, CLA
testeract.com
(3,424 Views)
