NI TestStand
Frequent Error loading DLL issue
I've been experiencing an issue in my line for quite some time. It typically occurs when we restart the PC or, at times, even just the application.
Our usual solution is to power off the PC and wait at least 30 minutes before turning it back on. However, sometimes even this doesn't resolve the problem.
This error doesn't occur when I run the sequencer using the TestStand Sequence Editor, but it appears when we use the GUI.
(575 Views)
Look at the step Properties settings by Clicking on the "Disconnect RONIT_ONLY" step in "PostUUT" sequence in "Arxtron Sequencer.seq" file.
Change the Run Options to Load Dynamically and see if the issue goes away.
(567 Views)
