NI TestStand
For loop in teststand
inside the for loop, there is a step, i can choose pass or fail, if pass, go out of the for loop, otherwise will loop.
But not sure why, as long as i have ever choose fail, the result of the whole sequence is fail
Keep moving
(6,392 Views)
Let's say I am looping through a bunch of digital output lines from a UUT.  In a FOR loop, I set the value the UUT should output and then read the output.  By your logic, as long as the last output worked correctly, it is an overall pass.  That is not desired.  Each output that is tested contributes to the overall pass/fail of the sequence.
(6,377 Views)
Thanks for your quick reply.
You mean the output of each loop, will contribute to the overall pass fail ?
I want the output of last loop, to decise the overall pass fail, how to make it ?
Keep moving
(6,374 Views)
You can use SequenceFilePostResultListEntry engine callback and set Parameters.DiscardResult=True if e.g. (RunState.Caller.Step.Name == "Test") && (Parameters.Result.Status == "Failed")
Or use for loop only for measurements and compare with the result after looping.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(6,348 Views)
Thanks, it is a pity, i use teststand 2013.
Keep moving
(6,343 Views)
Accepted by topic author Brzhou123
I saved it in 2013 but I don't have this version so I can't promise it will work 😕
Michał Bieńkowski
CLA, CTA, CPI
(6,303 Views)
Hi Sir
I have run your file, still the same, failed, maybe need other solution, but still very appreciate for your quick response
Keep moving
(6,240 Views)
