NI TestStand
Flexible DLL error code message
HI,
I'm using a flexible DLL Action step (C/C++ DLL).
The Returned value go to a local error variable.
The result Action is set to 'If value < 0 Set Error occurred to true'
Set ErrorCode is checked.
Now, I get a run time error with the error code displayed.  I would also like to display an error message.  How can I do that.
I can write the messages myself based on the error code in case the dll does not return a code message (which I don't know how to check).
Rafi
(3,456 Views)
Hi Rafi,
If you pass the SequenceContext or step Step.Result.Error.Msg to your DLL - Function you can set a string
to Error.Msg
If an Error occures in the ErrorMessage-Popup the ErrorString will be displayed.
I hope this was you are looking for
Greetings
from the Lake of Constance, Germany
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,451 Views)
Hi Juergen and thanks for your answer,
Yes, this is what I am looking for. However, this is a case where the dll is given to me, so how can I pass the Step.Result.Error.Msg ?
I tried to use Step.Result.Error.Msg in the post expression-- to write a message based on the error code, but it didn't work.
Any idea?
Rafi
(3,436 Views)
Hi Rafi
Try this
Greetings
Juergen
--Signature--
(3,406 Views)
