NI TestStand
Execution Time Format
I want to get rid of the decimal portion of the Execution Time that prints on my test report. At a minimum, I want it to display only one significant digit. Below is the expression that is found in the reportgen_txt.seq for the
f(x)Add Execution Time. What I'm wondering is, 1) how do I modify the format, 2)In general, how do I find out what is allowable in this expression.
Locals.Header += Str(ResStr("MODEL", "RPT_HEADER_EXEC_TIME"), "%-30s") + (PropertyExists("Parameters.MainSequenceResults.TS.TotalTime") ? Str(Parameters.MainSequenceResults.TS.TotalTime, Parameters.ReportOptions.NumericFormat , 1, True) + ResStr("MODEL", "RPT_HEADER_SECONDS") : ResStr("MODEL", "RPT_NOT_APPLICABLE")) + "\n"
(3,426 Views)
The format for the Str() is Str(value, , , , )
as you can see the format string is the second parameter. This is normally Parameters.ReportOptions.NumericFormat which is set as default in the Configuration Report Options as %$.13f, this is a C (printf) style format string. Which is a float with 13 places of precision.
Therefore you can changes this to say %$.1f which would be 1 place of precision.
Dont change it in the Configuration Report Options because this will affect everything, such the results, limits and so.
Regards
Ray Farmer
Regards
Ray Farmer
(3,425 Views)
Wouldn't I just change it right in the expression that is found in the reportgen_txt.seq. This should only effect the Execution Time that shows up at the top of my report, correct?
(3,423 Views)
Yes, sorry I didn't make myself clear enough.
Yeah the Step 'Add Time'
Ray.
Regards
Ray Farmer
(3,420 Views)
