NI TestStand
Event when Sequence changes
Hi!
In my GUI application I need to get the name of 'Sequence' when 'Sequence' of an Execution changes. Is there any event to get this change. Please help
(2,838 Views)
tsgy,
I couldn't find an event that would notify you of when the sequence of an execution changes, but you don't say why you are trying to use this information.
If you just want the name of the sequence for display reasons, then you can use any of the TestStand UI Controls, such as the Label.  Then you can use ExecutionViewManager.ConnectCaption with the Caption Source of CaptionSource_CurrentSequence
Josh W.
Certified TestStand Architect
Formerly blue
(2,797 Views)
If you do that, you might also be interested in the Label.ConnectionActivity event.
(2,781 Views)
