NI TestStand
Evaluating .NET structure
Hi everyone !
I am using Teststand 2013 and I am successfully calling functions from the "FlashMagicPS" .NET DLL/API
(like Connect, ReadSignature, Program2, Verify and Disconnect)..
This all works fine (most if the time)
Now I wish to evaluate the return value for better security.
I get a pointer to a structure, which also includes the desired "status int"
Q: How to open the structure (in the .NET DLL) and how to access and evaluate the value ?
(1,335 Views)
I don't know this library, maybe you could share more details about it? Do you know the exact structure of return values?
Mateusz Owczarek
Certified LabVIEW Architect
Certified TestStand Architect
(1,288 Views)
Hi.
I have a lot of calls like this:
Each call returns -a pointer- to a structure in the dll:
I wish to evaluate the "result" for positive (=good) or negative (=bad) numbers.
Thanks for any idea ...
(1,267 Views)
Did you see and try these:
https://forums.ni.com/t5/NI-TestStand/Import-structure-from-a-DLL-CVI-compiled-into-TestStand/td-p/1...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019WUeSAM&l=pl-PL
Maybe it will help?
Mateusz Owczarek
(1,263 Views)
