NI TestStand
Error when trying to import .nce file
I am trying to reconfigure my MAX configuration and I am attempting to use some previously developed .nce files to create the Switch virtual devices.  I ran the Switch device importer with the latest .nce file and I encountered an error. It looks like a syntax error in Endpoint1 but I don't know what I need to do to fix.  I tried to attach the full configreport but this website would not allow me to.
NI Switch Executive 3.6:
SwitchRelays
Note: Changing the port requires a restart of the RIO server or a reboot on the destination system.
Note: Select View>>Refresh or press F5 in MAX to see any settings that have changed.
Fatal Error: SwitchRelays failed to import. An error occurred while attempting to read from the file.
Invalid Endpoint1 "A35_VDD_10V " for Route Name "A35_VDD_10V-to-4113B1_6"
The channel specification string contains invalid characters or could not be understood. No match could be found for the given channel alias name or IVI channel name. Channel:A35_VDD_10V
*** Import FAILED ***
NI Switch Executive 3.6: error code 0xffff8e9
(1,187 Views)
I think I need to find out how I can convert a .nce file to a .ini file so I can edit it and then resave as .nce
(1,134 Views)
