NI TestStand
Error connecting SQL server with TestStand
Hello all,
I'm trying to process the result of the tests directly to a database in SQL server and I'm having the error that I show in the images. I already tested the connection with the database and all is OK.
I selected this database provider.
Someone can help me with this?
(3,319 Views)
Hi ,
There is DB Viewer in the tools menu.
Open it and connect to the DB with the connection string ( as you say its working fine).
Check for all the tables present.
If the tables are find in SQL server then try with a simple example.
Ravi
(3,294 Views)
Hi Ravi,
Thanks for your help.
I made what you have said and the connection is working correctly, but I don't see any table in the Data Base that I'm connecting. I need to create them, or they are created automatically?
(3,290 Views)
Hi Rodrigues,
The SQL to create the tables are :
C:\Program Files (x86)\National Instruments\TestStand 2022\Components\Models\TestStandModels\Database
(Change path based on the TS installed)
You can run thiD in the DB viewer which support SQL execution.
Ravi
(3,284 Views)
Hi Ravi,
I don't have this path.
Thank you for your help!
(3,233 Views)
Hello TiRodrigues22,
the paths are changing a little depending on the version of TestStand that you are using. However, the new files are often not far from the old ones.
I kindly invite yo to explore your TestStand files to see if you can find what you want.
For example with Testand 2024, I have the following path: C:\Program Files (x86)\National Instruments\TestStand 2024\Components\StepTypes\Database.
And if you really don't find the folder that you want, it may be a great idea to reinstall TestStand.
(1,566 Views)
