NI TestStand
Error code -17703 The CVI automation server is not registered on this machine
Hello everyone,
I am using Teststand. Also I changed CVI Adaptor to "execute steps in-process". But still ı have a error.
 Error code -17703 The CVI automation server is not registered on this machine.
(3,375 Views)
I noticed that this error only  occur when ı running DMM(4065) Self Test function. Except this ı can control DMM correctly.
(3,353 Views)
Hi standalone,
The error you're receiving appears to be saying that the CVI development environment is not registered as an ActiveX Automation Server on your computer.  Do you have LabWindows/CVI installed and configured in the adapter settings of TestStand?  Are you trying to run steps in an external instance of CVI?
Michael B.
Product Support Engineer
(3,342 Views)
No, I didn't install CVI. I am triyng to run steps in external instance of CVI.Also I changed CVI Adaptor to "execute steps in-process".
(3,320 Views)
